Can it be “fixed”, yes it can. The problem is the plastic is old and brittle. So even though you “patch” it, your just waiting for the plastic around the patch to break. If your goal is originality. Patch it and put it on the shelf for your concours judging.
Meanwhile if you want a functioning tray that’s actually slightly heavier plastic. This is what you want.
https://900designs-container.zoeysite.com/e...ent-rain-tray-1Have both listed above $88 for the late (which can be retrofitted), $110 for the early. It’s textured like OEM and you’ll have a hard time telling the difference other than it’s not cracked and broken.
If you need the metal tabs to mount you’ll need to order off the old site until we get the listing revised.
https://shop.914rubber.com/914-Early-rain-t...m?categoryId=-1
