jesservanzant
Mar 9 2019, 06:55 AM
I’m having some trouble with the headlights on my ‘72. Only the passenger side headlight wants to come up when I turn the switch on. I’ve swapped the relays out to see if that was the issue, didn’t change anything. The other side will raise manually via the knob on the back, but just not when the switch is activated. Any tips on where to go next? I’m new to these cars.
theer
Mar 9 2019, 10:15 AM
Yep- fuses first, then check for power at the driver side motor. Also, Try taking the in-op motor out and plugging it in the other side to see if it spins.
