QUOTE(VaccaRabite @ Mar 11 2019, 08:35 AM)
If you have an oil cooler (and you might need one for a 2056) it will take a lot of cranking to get oil pressure. Good luck!
follow up post;
filled the engine with oil and a zinc additive, hooked up the oil pressure sensor - gauge light turns green without cranking the engine. removed spark plugs, disconnected fuel pump wire.
cranked it about 4 times for 5-10 seconds each; gauge light never went off.
What's wrong??
I do not have an external oil cooler. the gauge is wired correctly as far as I know (pressure sender is a 2 pole unit). I do not have an oil pressure gauge - only the warning light.
so.....possibilities:
1. sender is not wired correctly? (the green/red oil pressure wire is attached to G pole on the sender)
2. oil pickup is clogged?? how would I check this?
3. I just need to keep cranking the engine over??
thoughts? help please
