QUOTE(BeatNavy @ Mar 12 2019, 02:32 PM)
I assume you're tightening the cable, right?
If you've been reading up on it you should know it's pretty straightforward, assuming it's set up now generally correctly in terms of hardware. Should be two 11mm nuts on the end of the cable. Loosen the lock one and make the adjustments with the other. Tighten up the lock nut again. You may need to add a spacer on the end of the cable to give you enough adjustment room. The cable can also be adjusted up at the pedal, if you run out of adjustment room at the tranny side.
Can't remember how much free play you are supposed to have in the pedal, but that should be in one of the threads you read. It normally doesn't take more than one or two turns of the nut to feel a difference, so adjust / test incrementally.
Thanks SO much...yes I am tightening the cable. I have read EVERYTHING I possibly could! Thanks again.
