partwerks
Mar 16 2019, 11:42 AM
With the parking lights on the front, and then you signal, is the opposite turn signal parking light suppose to stay on, or go out?
In other words, the opposite side that is signaling, will the parking light be on, or off?
Mar 16 2019, 02:13 PM
Ignition on or not?
If the car isn't running and the key is not in the column, only the side where the turn signal stalk points to will illuminate.
It's a common feature for European cars that allows you to only use the parking lights on the side that faces the road when parking.
partwerks
Mar 16 2019, 03:07 PM
QUOTE(rgolia @ Mar 16 2019, 11:46 AM)
Stay on
I must have remembered wrong then.
With the ignition on.
It was after the LS3 conversion, and so I wanted to make sure which way it was, so if there was a problem he could get it ironed out.
