Should I be reusing my push rod retainers? If not, who has them?
Thanks!
Konrad
dr914@autoatlanta.com
Mar 18 2019, 10:03 AM
yes will be fine, reuse them!!!
We have plenty of new ones on the shelf if you are missing one, though
QUOTE(krazykonrad @ Mar 18 2019, 09:01 AM)
Thanks!
Konrad
Mark Henry
Mar 18 2019, 12:51 PM
If they're bent tweak them with heavy needle nose pliers, many I see the ears are bent. I don't worry about if they're sitting right in the PR tube when cranking the rocker nuts down, I use smaller needle nose pliers to pull them up afterwards. This is also a must do inspection, they can be off center, but both wire corners should be engaged in each tube.
Common to see a shine where an errant wire was running on the PR.
