cpavlenko
Mar 18 2019, 07:52 PM
What's the best brand for pointless ignition for a 009 non vacuum advance distributor. I'm hearing per-tronix r not to reliable lately . Any suggestions .
roblav1
Mar 18 2019, 08:29 PM
Distributors are "pointless" in a crank fire ignition world!
cpavlenko
Mar 18 2019, 08:36 PM
QUOTE(roblav1 @ Mar 18 2019, 07:29 PM)
I'm not understanding u?
oakdalecurtis
Mar 18 2019, 09:12 PM
I installed a Crane XR700 about ten years ago. The car has never had a miss since then, best running improvement I’ve made so far.
roblav1
Mar 18 2019, 09:43 PM
"Distributors are "pointless" in a crank fire ignition world!"
I was just playing with words... a pointless distributor... a distributor is pointless (not needed) itself if you go crankfire.
Bad humor!
gereed75
Mar 19 2019, 04:27 AM
I have the crane optical “points” and XR700 also in my six with Bosch dizzy - cured a miss and very bouncy tach that I could not fix with any amount of fiddling using conventional points.
I suspect that the timing provided by this set up is more tolerant of wear in the distributor than points. Just my theory.
914Toy
Mar 19 2019, 09:12 AM
Make sure you connect the wiring correctly, if reversed, you will "fry" the unit - ask me how I know!
cpavlenko
Mar 19 2019, 02:23 PM
QUOTE(roblav1 @ Mar 18 2019, 08:43 PM)
Bad humor!
Mark Henry
Mar 19 2019, 02:33 PM
009 isn't the best dizzy for a T4, I'd snag old mallory red cap dizzy and use a pertronix or unilight module.
With MSD you could run on a single set of points (no condenser), the points would almost last forever.
