daveviola
Mar 19 2019, 08:16 PM
Has anyone added the external oil cooler that attaches to the transmission? I am running a stock 1.7 and wonder if this would help on very hot days.
Steve
Mar 19 2019, 08:32 PM
I have only seen them on track cars.
daveviola
Mar 20 2019, 05:46 AM
QUOTE(Steve @ Mar 19 2019, 10:32 PM)
thank you
IronHillRestorations
Mar 20 2019, 06:58 AM
Several people have mounted auxiliary oil coolers under the rear trunk floor with a fan mounted directly to the cooler. To add the cooler you can use a filter adapter plate that goes on before the oil filter, it's got the ports for the send/return to the oil cooler.
If your 1.7 is running hot, it's probably due to something else, like a mouse nest in the engine tin, or scuzzed up oil cooler, or your engine is worn out and has excessive blow by.
GregAmy
Mar 20 2019, 07:06 AM
Put in a camelcamelcamel watch for this item. Last week it was at $240 shipped.
https://www.amazon.com/gp/product/B000CIGEA0Street car hits megatemps during the summer so I'm mounting this under the trunk. I've been dealing with this since I bought it, can't explain it. Even had Chris install his
oil pressure relief kit and that didn't resolve it.
It's usually fine as long as ambient is 79-ish or below. But hit 81* and oil temps start climbing, eventually tickling the red (verified with the Mainly dipstick thermometer).
Steve
Mar 20 2019, 07:26 AM
QUOTE(Steve @ Mar 19 2019, 07:32 PM)
Sorry, I thought you were referring to a trans cooler.
