QUOTE(MiniStevieG @ Mar 25 2019, 10:41 PM)
QUOTE(MiniStevieG @ Mar 24 2019, 10:18 AM)
QUOTE(914Sixer @ Mar 23 2019, 06:39 PM)
I have a new Dansk tank in the box. You are going to have to turn the mount on the top around to make evaporator work. Has to be cut off and re welded.
Well that sucks a little thanks for the info. Might hold off now till I find something different.
Went ahead and pulled the tank out of my 75’ today. It appears to be in very good shape so I’ll be putting it in my 73’ for the time being. Question on the fuel lines however, Fuel hoses are 8mm (return) and 9.5mm (supply) correct?
I’m going to go ahead and replace the tunnel lines with stainless steel while I’m in there as well. I’d like to clean the tank before installing so what product do you all recommend?
Thanks everyone.
Evaporust, Apple cider vinegar, ect. Once you clean it, neutralize with baking soda and water, dry and then swish around some MMO - marvel mystery oil..
I don't use any liner or coating, neither did Porsche.
