QUOTE(Mark Henry @ Mar 24 2019, 12:36 PM)
The wife's 914 has repop sails that have bubbles, 4 year old resto so it isn't rust, the glue Mike (PO) used is letting go. Don't know if the sails are 914rubber, look good but definitely not OE sail material.
Think they will come off without self destructing?
I'd rather leave it till the end of summer if they're going to be a biotch.
Mark,
A heat gun or hair dryer might loosen it up, but probably not enough to not self destruct.
You could try poking the bubbles with a pin or sharp tipped Xacto knife, then use a plastic burnisher or squeegee to push the air out of the bubble in a circle from the edge to the hole all the way around each bubble, & burnishing the vinyl back down as you go, then seal the pin-hole with a tiny dab of black silicone on a toothpick to close off the holes.
Tom
