Brent,
Yes 1-2 years may be okay if stored properly away from heat & hot-cold temp changes, & away from sunlight/UV - so sitting in a shed or on a display rack in the window doesn't qualify.
And since you usually are only safe with about 8 years from the mfg date for safe use, then you're getting a lower useful life for full price - unless they're willing to discount the NOS tires for you by a comparable amount.
I've had to replace 10 tires on my 2 running cars ($ + spare at each) in old school OE sizes a couple of years ago, which were cracking on sidewalls & in tread grooves well before the 8 years - so that is a hopeful target life - & very expensive!
IMHO - you'll be better off to order some new less than 6 mos. from mfgr date - & tell them NOT to offer you their suppliers' old stock older than that - or to get them from Tire Rack with the same proviso. You'll just need to wait a week or so.
Tire Rack also has a bunch of good tech articles at their website's tech section on this & other subjects.
IIRC, those Firestones would've been made in China, so not really the old school USA made "Fire-Rocks" of yore!
Also, that 195/65HR15 (you can use T, H or higher speed rating on your 2L) size is still available from other tire makers today, plus Vredstein & other mfgrs still make the OE 165/80HR15 tires that came on our 2L's.
Frankly when I tried a set of 195s back in the day early 1980s when my 73-2L was my DD, I didn't notice much better handling/grip - if any, but I did notice that they rubbed on my inside front wheel housings on near lock turns (well before full lock-to-lock) - which was a negative, so I went back to 165SR15 which was all that was available then in 165 (HRs are available again nowadays).
Also, 195/65R15 will give you a 3-4% odometer/speedo error IIRC (check a tire size calculator online for tire size change errors) - so you'll have "Ghost Mileage" building up on your fresh resto if you go with them. Whereas 165 has zero error, while 185/70VR or HR 15's & 175/70 or 75 VR/HR 15's have negligible 0.x% error.
You can also try Lucas Tire in Long Beach CA to get Vredstein & other vintage make tires in the 165 & many other sizes noted above, & will ship to your shop - & usually at much better prices than Coker.
https://www.lucasclassictires.com/Look at the nailed Wheels & Tires thread in the O&H Forum for more tires info along those lines.
PS - bottom line is that yes, you probably can use them, but they may not last 8 years &/or they may rub on your fenders (some can rub rear outer fender lips as well, if they've not been "rolled").
Also, the rubber can also disintegrate from the inside unseen, & actually driving on the tires is better than unsed, because it apparently gets the rubber emulsifiers to move around in the tires & keep them pliable.
Good Luck!
Tom
