So here's my build sheet for 3.0 1974 914 six conversion, what's the engine and the rest of the drivetrain worth?
The build was well documented here's the thread
http://www.914world.com/bbs2/index.php?act...=0#entry1993833Engine 3.0L, 70.4mm X 95mm, 10.5: 1 CR
Case, 1979, 3.0, serial # *6399XXX, 930/13, 930.101.104.4R, Supertec head studs
Crank, stock, std/std, polished and magnafluxed, converted to CW distributor drive gear.
Rods, stock, rebuilt big and small end, new bushings, ARP bolts and nuts.
Flywheel stock lightened, with custom 914-901 adapter ring, CSP 228mm bus HD pressure plate.
Full engine balance, pressure plate and adapter ring balanced separately and as a full complete assembly.
Main bearings, new glyco, DFL (Dry Film Lube) coated.
#8 Main bearing, original Porsche, DFL coated.
Rod bearings, new glyco, DFL coated.
Intermediate shaft bearings, new Porsche, DFL coated.
Gasket set, new nose and rear main seal, Supertec sealant kit.
Pump, stock, cooler stock 911 modified to 914/6 spec.
Pistons, Mahle, new, 3.0 custom RSR style, 10.5:1 CR, DFL coated skirts, ceramic coated tops, Goetze rings.
Cylinders, stock 3.0 nickasil, replated Milenium/LN engineering, stock gaskets, .025mm base gasket.
Heads, 3.0 big port, port work, twin plug.
Valves, stock size, exhaust new TRW sodium, intake new AE.
Valve springs, Eibach sport, retainers early stock, keepers stock modified
Ceramic chambers and exhaust ports.
Cams, WEB-CAM, 120/104, set at 5.2mm/.10 lash, 964 cores modified to 901 spec.
Towers, spray bars R&R, tapped and cleaned, rockers resurfaced, RSR rocker shaft seals.
Chains, new IWIS, new cam sprockets, keys and pins.
Tensioners, hydraulic, no fail modification.
906 style cylinder cooling deflectors.
Cooler, stock, 3.0, modified for 914.
Oil tank, DWD, aluminum, with console and neck
Custom breather tank and OE hose.
Oil, Brad Penn break in, Delo 400 15w40
Carburetors, Weber 40mm IDA, rebuilt, new carb kits, 34mm venturies, 135 main jets, F3 emulsion tubes, 180 air correction, 55 idle, Ported stock manifolds, custom phenolic spacers.
K&N filters and rain hats, Weber linkage
Walbro fuel pump and PMO regulator.
Distributor, PMS/Jarvis, CW, MSD internals, Jaguar XJS-12 cap (1989-1996), Jarvis rotor (RSR clone)
Plug wires custom labled twin plug, Patrick Motorsports
Ignition, MSD 6AL, twin MSD high vibration coils, max RPM 6800
Spark plugs, NGK BPR5ES (BPR6ES also available for tuning)
Headers, 914, 1-1/2” MSDS, ceramic coated
Muffler/collector Magnaflow custom stainless steel 2-1/2”
WMS O2 meter, wideband
Transmission914, 901, side shift rebuilt, using good used parts
Gasket set, Elring
Gearing, custom, A,F,O,X, HB
Stub axles 108mm 911/901
Spare 2nd rebuilt transmission with stock 914/4 gearing
Axles, Sway-Away custom, part# 2420 directional L and R mark to the outside
CV, Lobro, G50 108mm modified to '1969-1974 spec grease seals
Rear hubs and stubs, 5-bolt Porsche,1972 911, new bearings
Bilstien, shocks, 140lb springs
Front struts, 914/6, Bilstien struts, 5-bolt hubs,
Turbo tie rods, ball joints, and bearings all new German.
Free Motion needle bearings for the front, Original Customs
Sway bars, Tarett front and stock rear
Front calipers, Brembo aluminum, Alpha Romeo GTV-6/Milano (1984-86), rebuilt with 911M kits
Front pads, 1971-72 bus modified,
Front rotor stock vented 914/6, drilled
Rear calipers, PMB V-calipers, stock 914/4 modified for vented rotor, stock rear pads.
Rear rotor stock vented 911, diameter reduced 5mm (10mm total)
Fuchs 1975 “020” 5-bolt Porsche refinished
Spare 944 turbo "outlaw" space saver,
