For sale a complete D-Jet system from a 914 GA engine less the aux air regulator (AAR).
Asking $595 (plus applicable shipping) or best reasonable offer. Really want to sell as one system, but if no reasonable offer received will piece out.
The MPS is worth several hundred dollars alone.
This 73 system is to be used with the 270 ohm resistor in line with cylinder head temp sensor (supplied).
Please ref photos as included
MPS 022-906-051C TESTED and in 5 minutes has little leakage from a set vacuum of 15" to just above 14". Very acceptable
Complete distributor 039-905-205 with the trigger point installed and working vacuum advance - but entire unit not tested
Throttle body 039-133-067 not tested
7 green injectors 039-906-031 not tested
ECU 022-906-021E Bosch 0-280-000-037 with attached harness and mounting bracket. Harness sheaving is hardened in most places, some connectors should be re-soldered, but otherwise intact and rebuildable and usable. Not tested
Cleaned and freshly painted air box with the cold start valve 311-906-171B, air intake temp sensor 311-906-081A, and thermo switch 311-906-161C. None tested
Ballast resistor 039-971-762A appears to be open, so included is a 270 ohm radio shack resistor
3 port fuel pump not trested
Decel valve 039-133-551 not tested
Fuel pressure regulator Bosch 0-280-160-001 not tested
Air intake tubes freshly painted
Air cleaner housing 2 parts freshly cleaned and painted
Left and right fuel rails
Note: no gaskets, hoses, seals, o-rings, air cleaner element, etc, or other hardware included.
System sold as is, no warranty offered or implied, no returns, what you see is what you get. Am cleaning house.
Thanks
jjs3rd914
