Any ideas about using MB Brembo calipers with an adapter on either 3” or 3-1/2” spacing 911 struts?
Seems as though the rotor size is very close in size.
911 vented 282mm x 20mm thick
03+ c class vented 288mm x 23mm thick
They are really plentiful and cheap on eBay. Looks like they could be easily split and the Center machined down a couple mm to work better with the 911 rotor thickness.
Thinking about buying a set and seeing what is involved in making an adapter.
