63acornwall
Apr 5 2019, 11:07 AM
Looking up from underneath , passenger side , close to firewall and heater tube .
When you put your fingers in it at bottom you can feel top of a box section ( ?longitudinal)
I guess this was a piece of non structural sheet metal but not sure what you call it
Is it serious / tip of a rust iceberg
Spoke
Apr 5 2019, 11:41 AM
That area is called the hell hole since it is rusted on most 914's. Likely there is more rust below. That's why most 914's are sold as "rust free" since additional rust is free.
theer
Apr 5 2019, 12:07 PM
Yep - could be the tip of the rustberg.
The missing piece is non-structural, but it is functional. The purpose is that it is part of a continuous "shelf" around the motor to seal, as well as possible, the fresh cooling air coming in from the top, from the hot air expelled underneath. Missing it may not have a big impact on cooling, but it is an indication that rust may have penetrated the long on that side.
Spoke called it: Google 914 hell hole then decide if you want to poke around some more.
burton73
Apr 5 2019, 01:16 PM
What is your situation on this car? Own, selling or restoring.
How does the right side long look under the rocker cover at the area close to the jack post?
Bob B
brant
Apr 5 2019, 01:26 PM
I would question that this is a "non structural" part of the 914 frame.
all of the leverage from the rear suspension terminates here in the frame, at the hell hole. The unit body requires all sides of the frame (including top) to help gain its full strength
and yes, your rust is much larger than just the hole you see
the typical repair involves cutting a portion of the rear fender off to access the hell hole and then repainting the exterior fender after it has been welded back on
thus the "hell hole" name
76-914
Apr 5 2019, 01:28 PM
Preliminaries don't look favorable. That coating of tar is covering something.
injunmort
Apr 5 2019, 03:16 PM
I beg to differ. imho, very structural, that's the long. no doubt tip of iceberg. fixable but welding and fabricating.
