I have dropped the engine in my 73 914 1.7 FI to replace the battery tray and support. Since it is out I decided to slide down the slippery slope of removing the tins, replace the front and rear crank seals along with push rod tube seals and clean it up a bit. Upon further inspection the seals from the cylinders to the case should be replaced also. That means pulling the heads and cylinders. A good friend who is assisting me has an extensive collection of nos parts and graciously offered to me a set of new pistons, cylinders, and rings along with all of the seals that I need. My engine id number starts with EB which designates it as a US (California)It was originally a California car. The EA is a US model. The US model pistons are 8.2:1 90mm, EB pistons are 7.3:1 90mm. The pistons that are being given to me are 8.2:1. Will there be any problems with using the 8.2:1 enlue of the 7.3:1.
Thnx Chris.
