SierraNevada
Apr 7 2019, 11:25 PM
They have mahle cylinders, not sure what pistons. The PO said JE, but unsure.
jcd914
Apr 7 2019, 11:40 PM
Often the manufacturer's marking is on the underside of the piston as part of the casting or forging.
I don't recognize the piston pictured, not OE though.
Jim
Mark Henry
Apr 8 2019, 04:40 AM
Is that a dome or a dish?
Mahle or KS is my first guess because the design on the left edge points to the flywheel, JE pistons don't have a piston pin offset. IIRC I think that flywheel mark is KS.
Also something to look for is JE pistons, or any forged piston, don't have full skirts.
NPR is also a possibility, they made T4 pistons back in the 80's, but the engraving looks more modern.
Mark Henry
Apr 8 2019, 07:41 AM
If it has a shallow dish it's a 914 stock 94mm 2.0 piston, likely a late replacement set. Deep dish VW bus, flat top 914 Euro piston.
Dome
NPR?
