My clutch cable came right out, no problem at all.
The throttle cable on the other hand didn't want to come out.
The plastic sleeve on the cable inside the metal tube would move about 3/4 of an inch out before it stopped solid. I could pull hard on the cable itself and it wasn't going to come out. I was able to free the plastic up enough to push it back in flush with the end of the metal tube at the firewall. I could push it in and pull it out but just that 3/4 inch.
With a mirror and light I found in the tunnel that the PO melted the plastic sleeve when he repaired the clutch tube, probably when he welded up the opening he cut in the top of the tunnel.
I ended up cutting the cable at the engine end and jamming some of the strands into the sleeve and pulling the cable and sleeve out through the front of the tunnel.
It could have been worse but this is on par with the work the PO did, some good and some not so much.
Jim
