FINALLY I'm getting back to my 914!
It's a '74, was 1.7 but PO had the dreaded engine fire. He replaced 1.7 with a Weber carbed 2.0, and did a few other things, and sold it to me as a roller.
SO. I've got the fuel tank out, and I've put in steel lines down the tunnel to replace the guilty plastic lines.
I have a fuel pressure regulator to keep the carbs happy. I'd gotten a Facet fuel pump, but I can't figure out an arrangement of putting that in that makes me happy - it won't fit in the fuel pump blister.
I've got an OEM fuel pump, the kind with three ports, but I'd like to put in a modern pump.
Notably, the ports on the OEM pump are all on one end; the cylindrical fuel pumps I've found have one port at each end. I'll go that way if needed but would prefer to find a contemporary pump, shaped like a cylinder so it'll fit in the blister, with the ports both on one end, so I don't have to put a U in the plumbing.
If you've put a fuel pump in a 914 recently, carbed or not, what did you use?
(Also - it's good to be back - I missed this forum.)
