I am selling this for someone else, Its a 2056 engine with
Motor has stock crank rods and oil pump
has 96mm kb pistons and the cyls are from European Moto rworks in Hawthorne
only other modification it has is a NOrris cams 272x cam
It was being run with a single carb however I strongly recommend a set of duals, we are selling it without induction, i just left it on to keep the dirt out of it.
I did pull one runner set and the passenger side tin because i dropped a crows foot into the tin trying to remove the oil pressure sensor line.
Its not spotless under the tin but its certainly not a mess.
motor has around 8000 miles on it.
comes complete with tin and fan shroud however no alternator.
Ran well when pulled, reason its being sold is its a spare and not needed now.
we built another identical engine on a run stand and put fuel injection on that so rather than move it over to this motor im going to install that motor directly into the car.
asking 2k can be seen in Costa Mesa ca.
https://imgur.com/gallery/xS9bZVc?fbclid=Iw...mKnIAADXDxYwmcM
