Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos.
So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression.
102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins.
78 mm crank - New this time!
H-beam Rods 5.325 with Type 1 Rod Journals
LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters
SPEC Clutch Kit - Stage 1 Lightened flywheel
Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear,
chromoly pushrods
Intake
Valve Lift: .500
Duration: 284
Duration@ .050": 250
Exhaust
Valve Lift: .500
Duration: 300
Duration@ .050": 270
Mahle bearings throughout
315cc/min Fuel Injector: Bosch 0280150945
48 mm CB Performance intakes. Dual throttle bodies with CSP linkage
Modified 30mm Oil Pump
Racewear Case thru-Stud Kit and Head Stud Kit
Tangerine Racing Remote Oil Cooler Kit
Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer
Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts.
Goal is to be done by Okteenerfest!
May have potential to be evil?
Thoughts suggestions?
