Andyrew
Jun 24 2005, 12:30 AM
So, flaring the fenders for the Neocar proved to be a bit of a challenge because its not a regular f/g car.. these have to be steel. So. This is basiclally how im going to make HPH style flares out of stock steel fenders... Hopefully
Anyways.. heres me starting to take the paint off the fender and reinforce it because streching the metal will warp the shape of the fender.
Hope you aprove Felix!
Andyrew
Jun 24 2005, 12:31 AM
Next. nice clean fender, no filler, never hit. Other fender on the other hand... will get replacement.. lol, not going to show that one yet.
Andyrew
Jun 24 2005, 12:32 AM
notice shape. this will change.
Andyrew
back, semi stripped of paint and goo
Andyrew
Jun 24 2005, 12:34 AM
also notice the reinforcements that went into this. I can add more, but for now this might work, need to be able to get a english wheel in there... lol. everything is tached into place and can be removed easily with a grinder.
Andyrew
Jun 24 2005, 12:35 AM
more reinforcements.. notice 2 pieces..
Andyrew
closeup.
Andyrew
Jun 24 2005, 12:37 AM
oh ya, ignore the crappy welding.. I wasnt using a helmet, and I only wanted tacks on the fender, but the two bars being attached I just wanted strong.. will not affect fender at all
Andyrew
good look at the reinforcment bar, and the shape of the fender.
Andyrew
Jun 24 2005, 12:38 AM
more fender shape
Andyrew
Jun 24 2005, 12:39 AM
Last.
Comments, critiques.. ext are welcome... I want this to be high quality... so flame away (cept my welding...)
Andyrew
now.. In color!
McMark
Jun 24 2005, 12:45 AM
I just cut the other fender off my red car today for Felix.
Good timing.
Andyrew
Jun 24 2005, 12:47 AM
yay!
Give me lots of car to go with it? or.... Cus I could have used more car.... lol, but as you can see... I work with what I got..
jgiroux67
I'm confused, what exactly are you doing? Are these for another car or do you have plans on replacing the ones that are on your car right now?
McMark
Jun 24 2005, 12:50 AM
Nope. No more car.
Almost EXACTLY like the ones you've got.
Andyrew
Jun 24 2005, 12:52 AM
This is not for my car.
My car is getting f/g.
THis is for the NEOcar.
ie Felix's concept thing.. He wants steel, I want fiberglass.
Im building steel flares for his car because John cant do it because of his work schedule.
Andrew
Andyrew
Jun 24 2005, 12:56 AM
Alright, that will work perfectly fine mark! not like im going to say "NO, do it again!!!!"
at least its not less...
rhodyguy
Jun 24 2005, 01:04 AM
so you plan on flairing the fender then installing it? i went to the flair party for korijo. john had a strip of material that one would use to compare the size/shape of the flair, hammers, palm nailer, mobile plennishing tool. that was the method you used previously correct? i see you added some info but i'll just keep going. how do you keep both fenders (flairs) equal when they're off the car?
k
rhodyguy
Jun 24 2005, 01:06 AM
and, are you going to make moulds off the metal fenders for f/g copies?
k
Andyrew
Jun 24 2005, 01:12 AM
I will use lots of cardboard and templates to keep them even, that is the hardest part yes.
rhodyguy
Jun 24 2005, 01:18 AM
did john bring that long thin piece of material that adjusted to the shape to california with him? i can't remember the correct term for it. i would think you you need to weld in the supports while the fender was still on a car to start at a common point.
k
neo914-6
Jun 24 2005, 01:30 AM
Andrew,
Great start!
I mounted the front 8" Technos this evening and they fit flush to the body with the 1.1" spacer so I put the 1.7" to fill out the HPH flare some more. In other words the flare doesn't have to be as large as the HPH's but I'll view it from several angles with the wheels turned stop to stop. I'll take pics this weekend when I pull out the car from my narrow driveway.
Andyrew
Jun 24 2005, 01:35 AM
I recieved the fends like they where shown... thus I could not weld in the supports while they were on the car...
The metal is flexable anyways, and can be bent that little bit...
I dont think he brought a long piece of metal...
Andyrew
Jun 24 2005, 01:38 AM
ALrighty Felix! It will basically be what shape you want it to be... because I can put the flare up top, making it a big hoop... in the middle making it like the hph flares, and mine... down at the bottom (no... not that...) or a sharper crease simular to what you have on the back... but it might be hard to convey.. but still possible..
Andrew
banksyinoz
Jun 24 2005, 02:42 AM
just listened to the v8 oohh ya nothin like a no exhaust noise, cool
John Kelly
Jun 24 2005, 07:31 AM
Hi Andrew,
First, congratulations on being brave enough to attack the front fenders!
Shaping them off the car may present you with some serious difficulties. You may have problems welding them in place afterwards. I would add more bracing front to back across the wheel opening at a minimum. More than that would be even better. Make sure all your shaping is done with the shotbag pressed firmly against the metal. Thus will give you the best chance of not pulling the fender out of whack.
I would weld them on the car first, then shape them, but this is a good experiment for all of us to learn from. If you do get an english wheel, you could probably do all your smoothing with just a #2 anvil wheel. If not, a palm nailer with a nearly flat shaping die would stretch out the fender pretty smoothly for a lot less money invested in tools.
One more thing, always wear the welding hood even for tack-welding! Not worth the risk. I look forward to your progress.
John www.ghiaspecialties.com
neo914-6
Jun 25 2005, 07:37 PM
John,
Andrew had this same idea when I first asked you about it. Us Cali guys always think out of the cat box...
Andrew,
Here's a pic, gotta take more...
Aaron Cox
Jun 25 2005, 07:42 PM
pan on bracing the opening so it stays the same shape? across the bottom so it holds the same openeing????
jgiroux67
Jun 25 2005, 07:50 PM
felix, where did you get the black turn signal lenses? Do they flash bright enough for others to see it?
neo914-6
Jun 25 2005, 07:51 PM
from back, my driveway is very narrow...
Aaron Cox
QUOTE (jgiroux67 @ Jun 25 2005, 06:50 PM) |
felix, where did you get the black turn signal lenses? Do they flash bright enough for others to see it? |
look closey...
they are euros...some "smoke agent" applied
neo914-6
Jun 25 2005, 07:53 PM
QUOTE (jgiroux67 @ Jun 25 2005, 05:50 PM) |
Josh,
This was a dedicated track car so they are non-functional at the moment...
neo914-6
Jun 25 2005, 10:28 PM
QUOTE (rhodyguy @ Jun 23 2005, 11:18 PM) |
k |
K,
I think you are referring to the magnetic strip that allows you to see highs and lows in the shape...John forgot to bring it but I've seen it at his shop.
Andyrew
Jun 25 2005, 11:47 PM
Aaron, I dont quite follow your idea.. Bracing the opening? Its already braced by the extra metal there.... Also the little factory lip will be removed by the hammer... Bracing it would be hard and IMHO redundant. We'll see though.
BTW finished taking all the metal off the fender before I went to work, Tomorrow I will start work on the lip, then on the actual flaring of the fender after I make a couple tools.
Andrew
Andyrew
Jun 27 2005, 03:14 PM
Update:
Took the factory edge off today. In the process I think I broke all of my welds, and then I rewelded (I had some good practice yesterday welding on pot metal for 3 hours...) They should hold this time.
Yes the fender warped a little bit, Not much, nothing that is not fixable. but it did warp. Notice that it will not sit flush against the ground without provoking anymore.
Anyways, heres the pic. No flaring yet. just reshaping.
Andyrew
next
Andyrew
Jun 27 2005, 03:15 PM
next
Andyrew
next
Andyrew
next
Andyrew
Jun 27 2005, 03:16 PM
Next
Andyrew
Jun 27 2005, 03:17 PM
next
Andyrew
Jun 27 2005, 03:18 PM
Last.
Interesting so far. We'll see what happens when I stretch the fender a little.
TimT
Jun 27 2005, 03:49 PM
QUOTE |
One more thing, always wear the welding hood even for tack-welding! Not worth the risk. |
werd..
Chris914n6
Jun 30 2005, 03:27 PM
window tint.
MikeP
Jun 30 2005, 04:02 PM
ok i'm ready for more pictures......................................................................................................................
neo914-6
Sep 11 2005, 01:18 AM
QUOTE (MikeP @ Jun 30 2005, 02:02 PM) |
ok i'm ready for more pictures...................................................................................................................... |
me too.......
Andyrew
Sep 11 2005, 01:44 AM
lol
Actually I had more pics.. of my fenders, but my gf came over and we took some pics of her, and she started deleting the one's she liked.... and ended up deleting all the one's on the camera... lol
I'll get some tomorrow. (I will FINALLY freeking get some time tomorrow to work on them. (church till 10, work at 11-7pm. work on fenders after 7... and squeeze in some hw after that.... yippe.) (oh ya, saw my gf for 2 hours today, first time in a week... go got priorities man... lol)
neo914-6
Sep 11 2005, 01:53 AM
Dude I was out the door at 7:40AM to meet Jason at PickNPull, got a door glass from an RX7 to test fit. Close but almost is not good enough! Found alternatives but will post on the side glass thread tomorrow...
Jon came by with the fender from MarkD, guess we won't need it? I'm planning a BBQ for a few of us, maybe when MarkD can travel to our side of the country. I wanted to see Elmer's car run today but can't afford the time and gas.
dlo914
Sep 11 2005, 04:22 AM
QUOTE (Chris914n6 @ Jun 30 2005, 01:27 PM) |
QUOTE (jgiroux67 @ Jun 25 2005, 05:50 PM) | felix, where did you get the black turn signal lenses? Do they flash bright enough for others to see it? |
window tint. |
you could always go w/ the model paint, that comes in an small aerosol can, available at hobby shops. it's used to tint the windows on models. works fine for lenses. a few buddies did this w/ their corner lenses and rear lenses.
