QUOTE(VaccaRabite @ Apr 22 2019, 08:14 AM)
Is it the switch that s bad? Or something on the board?
Desolder and resoldering in a new switch would not be complicated task. Just get some solder wick or a solder sucker and you would be good to go.
If you can locate the bad component fixing it isn't complicated. Maybe a decent multimeter to check continuity between the switch and the various components.
Also, there is often a fuse. Are you sure that the fuse didn't blow at some point, making it seem like a faulty power switch?
Zach
I identified the switch problem right off. The light comes on when I start to turn the switch, then goes off.
If I bypass the switch by jumping 12 v to the bulb holder I get nice FM mono. But no AM. I have the schematics, and that is how I figured out where to add 12 v. The switch is ganged to the volume control pot.
I was wondering if anyone on the board does radio repair, and could provide advice.
I can afford to have the radio sent out for repair, but like other aspects of 914, such as machining and engine building, welding, painting and fabrication I like learning how to do things. Under those circumstances it is a miracle that I have two 914s on their own wheels. Maybe I should buy a radio repair guide from 1975.
