I have always used 3; 1 between the metal cover and screen, 1 between the screen and the tuna can and 1 between the tuna can and the case and never had a problem with leaks. So this time I thought why do I need a gasket between the screen and tuna can? I can see only 2 leak paths; at the metal bottom cover and at the tuna can to case so I only use 2 gaskets and it leaked
. I take it apart and reassemble with 3 gaskets and no leaky
So I'll continue to use 3 gaskets but don't understand why.
