QUOTE(Tdskip @ Apr 22 2019, 02:53 PM)
QUOTE(mepstein @ Apr 22 2019, 04:50 PM)
You can’t really assume anything. Cars can be low without stiffer torsion bars or springs.
If you don’t like the ride, figure out what you have and what needs replacement due to age and wear and then decide where you want to end up And what to replace to get you there.
Darn it man, enough with the hard won real world experience and advice! Simplistic answers only please.
So follow on - assuming I like the stance but not the ride I assume can I get to a comfortable ride while keeping the stance?
Thanks!
As Mark said - too many variable to assume anything - especially after 45-50 years of use & abuse on our 914s.
For example, the lower stance could be due to older worn sagging springs - stock or aftermarket - & ditto at the other end with torsion bars. Then again, could've been cut, adjusted the suspension mounting/perches, etc. - & the front T-bars have something like 2"+ of adjustment of ride ht. built in.
If you have records, try searching them for suspension work & parts, & then also you'll need to crawl under & start looking at stuff.
FYI - IIRC the stock factory rear springs were 90 lbs for ride comfort combined with the 80 profile OE tires (i.e.: 165/80R15), & the closest aftermarket coils that I recall are about 100 lbs - so you want to stick with close to stock for DD comfort.
You'll also end up with a harder & harsher ride with the stiffer aftermarket poly bushings all around, than with the OE rubber/soft-poly types - & the track/AX versions of the aftermarket bushings will be stiffer/harder/harsher than the street versions. So if you want a nice DD ride - stick with street flavor of softer poly bushings at all places.
Also, you'll have about 15% less "cush" (a technical term ;-) with 65 profile tires' sidewalls, compared to the OE 165/80R15 tires (SR on 1.7 & 1.8, HR on 2.0 & -6). So you'll get a better street/DD ride if fitted with the OE 165/80R15 size tires, but will lose some grip as compared to your current 185/65 & 195/65 tires - & those are also larger diameter, which results in both speedo & odometer errors (use a tire calculator to get the actual errors).
While I know that the hot topic 914 du joir on here is bigger engines, fatter tires & stiffer suspensions for the supposedly ultimate 914 - the reality is that the 914 was a pretty excellent mix of comfortable street ride with great handling as they came from the factory in terms of tires & suspension & engine options.
And if you want other non-car-nuts to ride with you - e.g.: kids, g-kids, spouses/GFs/SOs, parents, g-parents, etc. - then you may want to try to recreate the stock set-up.
Also of note - the USA 914s were shipped with the front suspension set 0.5 - 1.5" higher than was ideal - NOT for ride reasons - but rather due to the USA DOT's required heights for headlights at that time. So it was always common practice to drop the front end +/-1" using the torsion bars' adjustment, in order to get the car to ride flatter F to R, or maybe a tad lower. This also threw the weight balance forward & closer to 50:50 & improved handling/turning a bit.
So maybe look at your options for stockish with the copper car, then if you like it, do the yellow that way - or leave them as 2 "flavors".
There are some good 165/80HR-SR15 tires out there from Vredestein that aren't terribly priced, if the 185's are old & need replacement (or 195s, but 185s haven't been available much for a while in /65 - so I assume they're the older set). Then put the other set on the yellow car for the experimentation.
Also - a word of caution about the copper metallic 914 color here in CA - which probably applies everywhere else too - is that it looks like Orange in the sunlight, & therefore attracts as much attention from Cops & Chippers - as do red cars. Yellow is right up there too! Sports cars just add to the attention getting!
I know, having painted my 73 that color in 76 & racking up points until & changed it to the last (current) anthracite grey metallic "blacktop camouflage" color. My first car was a RED Open Kadett, which also caught too much attention.
So have your head on a swivel & radar/laser detector on sensitive whenever driving any of your 914s!
Tom
