QUOTE(VaccaRabite @ Apr 25 2019, 01:46 PM)
I have the full boat upgrade on my car too, and getting it adjusted took some time.
While tuning the shifter, make sure the up and down shift stops are backed off. You close those down last.
When I did it on my car, the shift rod itself was just barely touching something (I don't recall what) on the 4/5 plane that made those gears a bitch to get to. I had to relieve the impingement and suddenly everything went much easier.
As Andy said, you gotta start with the 2/3 plane.
Find one of DrEvil's posts and download the Shift Adjustment document that he has linked in his sig file. Its comprehensive and will get you there.
Zach
Sometimes the bolt in the tunnel next to the seats will rub against the clutch tube or a seatbelt bolt.
