Hello,
I am selling the engine that came out of my 1975 Porsche 1.8L. I swapped the engine out about one and a half years ago for a new, higher displacement engine. The original engine was in good running condition; oil pressure was excellent, and compressions were all uniform around 95-100 (both measured before removal). The engine was kept in my heated garage since, and it turns easily by hand and has good compression in all cylinders. The flywheel appears to be in good shape.
To the best of my knowledge this is the original engine to the car, and it probably had about 94,000 miles when the swap was done. The car had been converted to a single Weber carb setup before I got it. The Weber carb system will come with the engine, or you can check out a complete L-Jet system that I am selling separately (see my other ad).
The only small things missing from this engine are the spark plug wires, the thermostat, and the oil filler cap. The oil filler neck has a small hole that can be easily plugged. Engine comes with all the tin in good condition, with the exception of the right "wing" that is missing a small piece.
Asking $500 OBO. Located in Madison, WI. You must come and pick it up, I will not ship it.
