Oh boy . . . this is going to set a bunch of folks on fire.
Here are my short answer guesses:
1) Different engineers releasing fasteners potentially at different points in time before they were collected up into a Bill of Material and the Service Illustrations & Parts Lists. Remember all this documentation was done in a pre-computer era. All hand work & lots of paper shuffling.
2) May be related to assembly line preferences of how easy it was to place a particular washer.
3) Different p/n could have been different plating finishes (black oxide vs. zinc), different tolerances (OD and/or ID hole size), or maybe different part suppliers.
My strongest bet is #3
Now here's the fun part to
the pot.
Split ring lock washers ARE useless with respect to any ability to "lock" a fastener and prevent it from loosening. This is not some personal opinion said to be provocative. There has been an enormous amount of time and engineering spent since the birth of these cars to make fastener joints more robust.
Removal of lock washers from joints is a big part of increasing their robustness. You won't find split ring lock washers used on any modern automobile.
So my advice is don't sweat what type of lockwasher it is. Heck don't even use one. It won't amount to a hill of beans. If you don't believe me that's fine, but, please first go read the NASA report. All the major automotive OEM's have done the studies and engineering as well. Fastener joints are more robust without a split ring lock washer in there.
https://ntrs.nasa.gov/archive/nasa/casi.ntr...19900009424.pdfPages 9 and 10 are relevant to this thread.
Here is the NASA except on split ring lock washers:
Lock washers
The typical helical spring washer shown in figure 14 is made
of slightly trapezoidal wire formed into a helix of one coil so
that the free height is approximately twice the thickness of the
washer cross section. They are usually made of hardened
carbon steel, but they are also available in aluminum, silicon,
brome, phosphor-bronze, stainless steel, and K-Monel.
The lockwasher serves as a spring while the bolt is being
tightened. However, the washer is normally flat by the time
the bolt is fully torqued. At this time it is equivalent to a solid
flat washer, and its locking ability is nonexistent.
In summary,
a lockwasher of this type is useless for locking
