Chi-town
May 1 2019, 10:21 PM
Ok let me start this with the statement that I'm not looking for opinions or theories on the subject
I want to know has anyone actually done it?
I understand the bore to stroke ratio is over square
I understand that it won't have any low end
I'm not looking for reliability or 50k miles from it
Yes I know the heads will need worked and I'll need a spicy cam to really make it zing.
Have you built one? How did it run? How long did it last? Where did you get the P&C kit from?
I have a spare 1.8 that I'm willing to invest in just to see what happens.
Steve
May 2 2019, 12:24 AM
I had a 103mm x 71? 2 liter crank? The kit came from European Racing in the late 70’s. I had a 3/4 cam in it and dual 44 Weber’s. It sucked a valve before it made it to 10k miles. Over hauled it and then it broke a ring before it made it to 10k miles the second time around. It was very fast. Ran hot and I had to add an oil cooler. I jury rigged one to the engine lid with a fan. Later the car got rear ended on the avenue. It was totaled, but I was able to buy back the motor and sell it.
ChrisFoley
May 2 2019, 05:27 AM
I had one 20 years ago. I bought it already assembled and rebuilt it to cure oil leaks and other assembly issues.
I used it in my street car and then in my race car before selling to someone else.
The cam made power from 4500-7500 rpm, and had nothing below that, so leaving stop signs into traffic required a clutch dump.
It was the most powerful engine I've ever had in my race car. I think dyno numbers were around 200 peak hp. I reached 125mph at the end of the front straight at Summit Point during a PCA club race around 1999/2000.
Edited to add: mine was 102 x 66.
rhodyguy
May 2 2019, 07:01 AM
P/C are going to run $3680. WOW. Case work? Extensive. Heads, rods.. Better have ALL of your ducks in a row BEFORE you put the trigger. Don't forget the exhaust system that will support the build. You're going to spend a lot of $. A LOT! How do you intend to feed this engine fuel?
Chi-town
May 2 2019, 08:38 AM
I found a NOS set for less than $400, that's kinda the reason it peaked my interest.
The rest is easy/cheap/plentiful as it's still just a type 4 VW engine.
@ChrisFoley thank you! I expect it to perform exactly as you describe.
