pgollender
May 5 2019, 09:05 AM
Finally beginning the 1974 1.8 T conversion. Bought the donor car over 1 year ago and began stripping it out last week. The goal is to modernize the cockpit and cabin a bit to enjoy things like Cruise control and A/C and intermittent wipers and boast power a <bit>with a KO4 turbo. The donor car was a 1999 Passat 1.8T longitudinal 5 speed.
I was inspired by both Mike Bellis and Andrew Dallens conversions. I don’t have big aspirations for enormous HP gains. I’ll be satisfied at 165-175Hp.
I plan on using the original Passat gearbox and custom fab the axles and cable shifters.
Ideally I’d like to design the cooling system and intercooler to stay in the original engine bay, but we shall see.
pgollender
May 5 2019, 09:26 AM
Passat wiring harness, 100% intact. Bitch to remove. Many unneeded connections, but at least I can pick and choose. Instrumentation panel will be Passat.
pgollender
May 5 2019, 09:33 AM
Andyrew
May 5 2019, 12:46 PM
Watching
Let me know if you need any help.
165-175hp is stock turbo at about 12-13psi. Very conservative setup. You could make about 225 with the setup maxed out.
jb6000
May 5 2019, 02:12 PM
Going to be a nice car.
whitetwinturbo
May 5 2019, 07:51 PM
..............that's a challenging mash up
get off my lawn
May 6 2019, 03:54 PM
QUOTE(pgollender @ May 5 2019, 08:26 AM)
Click to view attachmentThat looks like a bad acid trip.
A really bad one.
pgollender
May 6 2019, 08:44 PM
QUOTE(Andyrew @ May 5 2019, 11:46 AM)
Watching
Thanks Andrew, I'm sure I will need to stand on the shoulders of those who have gone before me.
pgollender
May 6 2019, 08:46 PM
That looks like a bad ]
[/quote]
acid trip.
A really bad one.
[/quote]
Only worse acid trip is one in which you haplessly cut all the wires to make the job "easier".
914-d
May 7 2019, 12:58 PM
If you don't have it already, you are going to need vagcom or vcds as it is called now. Computer program for working on vag products.
Where in nor cal are you. I have the program ane might be able to help
Andyrew
May 7 2019, 01:08 PM
He can also buy the Chinese $20 cable/program. I havent had any issues with that.
Chris H.
May 7 2019, 01:18 PM
Yeah you really have to pull the whole harness just to be sure you don't accidentally cut something you need. Quite a BITCH to get out of the car but worth it in the end.
Looks like a clean donor engine/other parts! Check out Andyrew's thread as well as @MikeBellis Probably more I just don't remember.
Chris H.
May 7 2019, 01:19 PM
Double Post!
pgollender
May 8 2019, 02:53 AM
Power plant is out. Time for a cleaning and respec/rebuild
Click to view attachment The passat tranny has a low profile.
Click to view attachment1999 Passat wagon DBW decommissioned.
pgollender
May 9 2019, 12:53 AM
QUOTE(914-d @ May 7 2019, 11:58 AM)
Where in nor cal are you. I have the program and might be able to help
Roseville area. Thanks, I do have access to bonafide vagcom system !
falcor75
May 9 2019, 01:57 AM
Nice project, I built a Mk1 Scirocco with the 1.8T and it turned out plenty fast with just the stock 180 hp engine (traction was an issue into third gear) The Scirocco is a little lighter than the 914 but its only about 100 kg difference and rear wheel drive will make it awsome. If you want to keep the stock look I'd look at a small watercooled intercooler, much more efficient and easier to find room for.
pgollender
May 11 2019, 07:54 PM
Yellow car on it's way to new garage for body work and rust repair
pgollender
Dec 20 2022, 08:47 PM
Car on the spit. 1.8T on the stand
pgollender
Dec 20 2022, 08:50 PM
pgollender
Dec 20 2022, 08:54 PM
will clean up and rebuild forged internals, JE pistons, longer stroke
pgollender
Dec 20 2022, 08:58 PM
Original brain box from Passat donor = Audi. Will keep for start-up but replace before APR chip and tune
Click to view attachment Click to view attachment
pgollender
Dec 20 2022, 09:05 PM
Original K03 turbo. Will replace with slightly larger K04, better boost controller and air-to-water intercooler.
pgollender
Dec 20 2022, 09:21 PM
Front engine view: Will delete viscous fan, water pump, power steering pump (three cluster on the lower right). Relocate the AC (on the lower left) to where the PS pump is now to allow for cable shifter clearance and cleaner front. I plan on using electric water pump with controller to account for longer coolant push to front mounted radiator.
pgollender
Jan 15 2023, 10:10 PM
The moment you realize that it took you 4 weekends just to get everything apart and now you have to start to deplete your bank account.
Click to view attachment Last icky creepy step:
Click to view attachmentI may call her "Spidey"
pgollender
Jan 29 2023, 05:52 PM
Weekend progress: Got the heads back from the machine shop. I still haven’t found any local machine shop that wants to bore the Passat block. Seems like they all closed shop.
pgollender
Jan 29 2023, 05:59 PM
Old suspension is off. Getting ready to send out to get powder coated. Headed over to Shingle Springs to pick up my new coil overs from Ground Control. New Bilsteins, bushings and bearings arriving later this week.
pgollender
Feb 7 2023, 08:16 PM
First upgrades arrived today. Big shout out to Jay at Ground Control in Shingle Springs, California. I am literally starting at the ground up.
erwan914
Feb 21 2023, 04:19 AM
QUOTE(pgollender @ Feb 7 2023, 06:16 PM)
Click to view attachment Click to view attachmentgood project
spirings LBS for rear ?
pgollender
Feb 21 2023, 10:38 AM
QUOTE(erwan914 @ Feb 21 2023, 02:19 AM)
I went pretty stiff, 175#, but the front will be stiff too with 19mm torsion bars, Tarrett anti-sway bar, and adjustable Koni's. All new bushings everywhere and rebuilt steering rack. Once it's on the ground and running, I have a 150# spring option as well if i need to adjust the ride response. Trailing arms about ready to go. Waiting on the bearings.
pgollender
Feb 27 2023, 12:07 AM
Obtained accessory carrier and peripherals from 2002 Jetta and test mounted on the block to see if it would fit. This switches the AC pump (and everything else) to the left side of the block and gives a cleaner shot and more room for the cable shifters, turbo and the exhaust on the right side. First pic is the original configuration and the second is the new relocated peripherals.
Click to view attachmentClick to view attachment
Mayne
Feb 27 2023, 06:37 AM
Looking good! I’m guessing by the forged internals, etc, that stock power is out the window. Sounds like a good plan of action!
