QUOTE(GregAmy @ May 6 2019, 08:17 PM)
We got it started and re-calibrated to alpha-N.
I think someone here was ragging on SDS, because he couldn't tune it. I told him the cam was too hot, poor vacuum signal, tune with TPS only (no MAP sensor) and he said SDS was a POS if it had to be tuned this way.
MegaSquirts "AlphaN" is the exact same thing as SDS "TPS only", both bypass the MAP sensor and you need to use this for big duration cam(s).
Less duration/valve overlap cams don't have an issue like this.
To the OP, once fully kitted out none of these systems are cheap, there's nothing T4 off the shelf, so you need to fab items yourself or pay someone to do it. The dub shop puts together a "kit' for you but you still have to install and tune it.
Basically you have to research and learn how to tune the system, some systems it's a steep learning curve on the tuning.
