Price reduced to $12,000. Which is firm
Car is located in Deer Park, WA. (eastern Washington).
I have owned this Porsche for little over 10 years and have done all the work on it.
Motor is a 75' 2.0 L rebuilt with performance SCAT cam and solid lifters. New cylinders and pistons (94MM TO 96MM). Motor is equipped with Weber 44 IDF carburetors and set-up with a Pertronix IGNITOR ignition and coil. A BURSCH tuned exhaust system is also installed. Motor has about 360 HRS. on it.
Previous owner completed transmission rebuild and Porsche Silver paint job.
EMPI 15 inch wheels with new 60 series radial tires. Also have the original 15 inch steel wheels with hub caps and beauty rims.
Have service manuals and lots of extra parts with the car including the original 1.8L case. Also a transmission from the 75'. Speedometer works along with tachometer and full gauges. Blaupunkt CD and AM/FM radio in dash.
Mileage showing is 118,000. Odometer never did work since I got it, but it has only been on short day trips.
The car is in very good shape, always garaged and used only on fair weather days. This is a virtully a rust free chassis. Some in "hell hole", but it is cleaned up.
I will answer any questions are can provide more pictures upon request.
