I have a 1974 914 with a 1.8 ltr. engine and L-Jet injection. The fuel injection harness does not plug into the four prong connector on the relay board. I understand this is correct for the model. However, there is a wire embedded in the wrapped cable of the 12 pole connector housing from the ignition harness with a female connection. There is no apparent connection. Can you shed any light on that wire and where it should be connected? mschafer51@outlook.com
