Str1974
May 12 2019, 07:07 PM
I have a question regarding the back-up switch. I needed to replace it because the wiring connectors had broken off right where they plug into the two female connections on the switch (one underneath the back drivers side section of engine). I would have spliced the wire and connectors if I would have any length of wire left. All I have is bare wire and the two female connections. I've been trying to locate the right size bullet connectors that could be hooked up to bare wire, but no luck. The back up switch is easy to locate and purchase, but I cannot locate the male connectors. Any advise?
rudedude
May 12 2019, 07:20 PM
I think I've gotten them from stoddard
Str1974
May 12 2019, 08:02 PM
QUOTE(rudedude @ May 12 2019, 08:20 PM)
I checked with them , and no luck.
Chris914n6
May 12 2019, 08:32 PM
Common bullet connectors work. Might have stretched it out a bit, don't remember.
Bleyseng
May 12 2019, 09:58 PM
QUOTE(Chris914n6 @ May 12 2019, 07:32 PM)
Thats what I did
bdstone914
May 12 2019, 10:25 PM
@Str1974 I got the correct ones from Bel Metric. German made with double crimp on bare wire and insulated wire. I think they were 4mm.
https://www.belmetric.com/bullet-connectors...mm-p-11391.html @Bleyseng
IronHillRestorations
May 13 2019, 07:25 AM
SAE bullet connectors will work
dr914@autoatlanta.com
May 13 2019, 08:21 AM
we always have plenty of the solder in bullets available
Str1974
May 13 2019, 10:22 AM
QUOTE(Chris914n6 @ May 12 2019, 09:32 PM)
will do, thanks
Str1974
May 13 2019, 10:24 AM
QUOTE(bdstone914 @ May 12 2019, 11:25 PM)
https://www.belmetric.com/bullet-connectors...mm-p-11391.html @Bleyseng Wow, you guys are awesome. 914World rocks! I want to thank all you guys for your help.
Bleyseng
Jul 30 2019, 12:03 AM
Yes, I picked up some of these so now I just have install them.
mikesmith
Jul 31 2019, 07:06 PM
These worked well for me; generic 5mm R/C motor / battery bullet connectors.
https://www.amazon.com/gp/product/B01CQ2OMJE
JeffBowlsby
Jul 31 2019, 09:32 PM
4.5mm is the correct size for these terminals.
Jul 31 2019, 10:04 PM
I use regular SAE bullet connectors, I just cut them shorter, and crimp and solder them on.
