tailwind22
May 17 2019, 03:43 PM
Looking to buy a rear brake proportion regulator from a 914-6. Part number is 91435506700.
euro911
May 18 2019, 01:13 AM
Contact Eric Shea at PMB Performance. They can refurbish (restore) your existing valve.
Superhawk996
May 18 2019, 08:40 AM
PMB did mine.
Even if you find a used one, you'll still want to get it restored (assuming you don't already have a core). Rear proportioning is a critical part of the brake system and you want to have it working properly.
tailwind22
May 18 2019, 09:15 AM
Eric has done a lot of great work for me. Problem is I do not have the part and need to source it before restoration work.
May 18 2019, 09:21 AM
I believe a stock 4 valve can be adjusted to the 6 specs. They look identical on the outside.
