finchmunoz
May 20 2019, 05:23 AM
Hi.
Does anyone know where I can get a complete Subaru conversion kit? Cradle, cable shifter, etc.
The daughter is gonna start driving it and needed to make it reliable... I want t include the Subaru transmission so easier to drive.
Also, is this "reversible"? Meaning I can put back my type4 engine by just unbolting and remounting?
Thanks
Finch
Chi-town
May 20 2019, 09:33 AM
Nobody makes a good complete kit at the moment.
You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans.
May 20 2019, 10:59 AM
QUOTE(Chi-town @ May 20 2019, 11:33 AM)
There are a few suppliers of different parts that will let you put together a “kit”.
Besides the suby trans, which is a good idea, what engine are you thinking of and how much work can you do yourself?
I think everything can be easily reversible in the future. Even some of the mods that people do, like holes and clamps for the radiator and a welded bulkhead engine mount wouldn’t be more work to reverse than typical rust repair.
Chris914n6
May 20 2019, 01:28 PM
For the amount of money and effort to do a full swap you can make the VW reliable.
Chi-town
May 20 2019, 04:47 PM
QUOTE(Chris914n6 @ May 20 2019, 12:28 PM)
Did you just VW and reliable in the same sentence?
76-914
May 20 2019, 06:24 PM
True, but it will still be a 50yo antique with a diminishing supply of OEM parts. Throw a Subaru in there and when it's time for a repair you can get parts at an Auto Zone or throw another engine in it for <$1000.
finchmunoz
May 21 2019, 04:24 AM
QUOTE(Chi-town @ May 20 2019, 07:33 AM)
Nah shifting a 901 tranny is something I've given up on really.
finchmunoz
May 21 2019, 04:31 AM
QUOTE(mepstein @ May 20 2019, 08:59 AM)
Nothing too strong really. Just maybe the ej20 non-turbo.
I think the mounting is the easy part. It's the shifter I'm worried about. Does anyone know how to convert from the 914 shifter to a Subaru shifter? (Do I need to)?
May 21 2019, 05:59 AM
Sorry dp
May 21 2019, 06:00 AM
QUOTE(finchmunoz @ May 21 2019, 06:31 AM)
A company called very cool parts.com makes a shifter, cable, linkage setup for the suby trans. Or you can just use their linkage and use a stock shifter from an mr2 and 7 foot cables.
@finchmunoz
Chi-town
May 21 2019, 08:42 AM
SW20 MR2 shifter, cables and Bell crank system are readily available thanks to the FFR 818 guys.
Stick with an NA motor. Wether it's a 2.5 or a 3.0/3.6 they all make way more power than a beginner driver needs in a 914.
The turbo motors create headaches with intercooler mounting and air flow.
And stay away from the jdm imported engines!
JOEPROPER
May 21 2019, 04:38 PM
QUOTE(Chi-town @ May 21 2019, 10:42 AM)
What's wrong with JDM engines???
finchmunoz
Dec 29 2019, 10:39 PM
I'm in the Philippines. Labor is dirt cheap. So I guess I can have someone do the work for me. Problem is the "know how" and finding the right parts.
Traffic is so horrible here an stock 1.7L air-cooled engine with air conditioning will overheat here.
finchmunoz
Dec 29 2019, 10:43 PM
So, anyone here recommend a kit to adapt an ej20 engine to my 71 using 901 transmission? Maybe I'd just get a rennshifter instead.
Chi-town
Dec 29 2019, 11:37 PM
You can get the parts from Renegade hybrids of you want to keep the stock trans
Steve
Dec 30 2019, 11:55 AM
Everything is reversible except for the hacking of the front trunk for the radiator.
Mueller
Dec 30 2019, 12:01 PM
Kennedy Engineering will have a kit to adapt the engine and transmission together.
The rest of the swap has to be put together from other sources.
https://www.kennedyeng.com/engine-adapters
ahycaramba
Dec 30 2019, 12:52 PM
From my experience I highly recommend doing the work yourself. You have control of quality over your own project. When you rely on others you are at their mercy financially and your projects definition of quality may not be at par with yours.
Other than the plenty of great advise and articles here on the world I have found a couple of good pages on Facebook that would benefit you.
“Subaru powered Porsches” and “Subaru Powered Volkswagens”
Good luck on your project.
914forme
Dec 30 2019, 05:40 PM
QUOTE(Steve @ Dec 30 2019, 12:55 PM)
Even that is reversible if done correctly
just like fixing rust, or that hole that got cut in the front for A/C by the dealer with a screwdriver and a can opener.
Jonathan Livesay
Dec 30 2019, 06:05 PM
QUOTE(914forme @ Dec 30 2019, 03:40 PM)
I've never seen a better description.
thelogo
Dec 31 2019, 09:48 AM
Drove my stock 1.7 for 7 years semi- daily.. Reliable as could be
After a 80 dollar tune up
Valves adj. Oil change, plugs , points etc
Chi-town
Dec 31 2019, 10:11 AM
QUOTE(thelogo @ Dec 31 2019, 07:48 AM)
The anomaly is not the norm
