After just converting the 1.8 back to L-Jet the engine is very rich at idle and light load to the point of misfire. It will smooth out under moderate to heavy load. The new FJ6 injectors are suppose to replace B022 906 031C which are listed in AutoAtlanta blow ups. The fuel pressure is right around 37psi. The ECU is correct (473 906 021) for engine code EC 043 518 and the AFM is correct (473 906 301) and newly rebuilt from AA as well. The idle adjust on the AFM could not fix it. It puffs a bit of black smoke sitting at idle.
My next idea is to check the CHT. Any other suggestions?
