QUOTE(Superhawk996 @ May 27 2019, 11:11 AM)
Then why not just put them back how they came from manufacturer? There is not a way to get more articulation from a CV joint than it was designed for.
I am an engineer that has worked in automotive manufacturing and engineering for a long time. The chance of them having been assembled wrong by the supplier is less than 0.3%.
Assembly lines usually have all sorts of automated visual inspection and error proofing as well an end of line human visual check.
Can bad parts happen. Sure - lightning can strike the same person twice. It HAS happened though statistically irrelevant. Same for mis-assembly of a CV joint by the manufacturer.
Sorry if I'm coming off like a jerk. Nearly all modern manufacturing is done to six sigma to ensure you don't get bad parts. The chance of you having gotten two of them misassembled in the same way is statisticalnp ly zero.
https://en.wikipedia.org/wiki/68%E2%80%9395...%80%9399.7_ruleNp was just going on the opinions of others, for this particular CV, my question has come up many times before without a manufacturer explanation . And it was 4 CV’s I bought all assembled the same way!!! I just always welcome the insight of you and the others in this community, as I’ve learned the hard way assuming things can not always be the best course of action. I’d rather ask a stupid question as I m not an expert at anything unless you consider me an expert at nothing
I appreciate your feedback and happy 914teening.
