This 914 is an ill advised project fueled purely by my desire to create the most fun car ever built. Fun is objective, but in my opinion, it means- low weight, high revs, the right amount of power and a tight communicative chassis. Too much power or no confidence in the car and you can easily tip the scale into scary. The 914 is known to be an excellent handling car, full of character, communicative... with a 1.7L lawnmower and 5800 RPMs of fury. I would love to keep this motor and build it up and make it great if it were easy or relatively inexpensive, but it's neither. My car is no concours restoration car. I bought it for it's Porsche handling and because it's California smog exempt and I can do whatever I want with it. Also, I just love 914s!
Enter the 4A-GE Blacktop. Originally the motor was a road going version of the Cosworth BDA twin cam engine, and was found in the US AE86 Corolla GTS or the famed Sprinter Trueno, and then later in the AW11 MR2. This particular revision, the "Blacktop" is the final revision of the 4A-GE found only in JDM late 90's Toyota Corolla/Levin/Sprinters. It's a 1.6L that makes 165hp and 120 ft*lbs of torque, 11:1 compression, individual throttle bodies, 5V per cylinder, revs to 8300 RPM and runs off a MAP sensor, allowing it the ability to fit glorious velocity stacks as a bolt-on upgrade.
I happened to have gotten my hands on one of these, and so the project begins...
First things first, I'm currently giving the motor a refresh. As expected the JDM importer guys lied a little bit and it's not 60-80k probably more like 80-100k on the motor. I will be doing the timing belt, crank and cam seals, valve cover gasket, spark plugs & seals, and the oil pan gasket. I already have my adapter from KEP and next thing will be to remove the old type IV and test fitting the blacktop with this nicely rebuilt side shift 901 I happened to have acquired. Hopefully I will be starting on that in June.
