Hi all,
I have been struggling. I have read through this forum and combed the internet for solutions to my problems. No not personal problems but electrical problems. It seems for every step I take in the right direction two other things go wrong.
My original turn signal and wiper switches were worn and not working well. Although they did function when I originally purchased the car. Since then I have purchased new switches for the windshield wipers and turn signals. I have also purchased all new LED lights from Spokeworks. I also purchased the new relay from spoke to work with the LED's.
Now for the weirdness.
1. Horn switch is a little different than the original. I soldered on a new female spade connecter as the old had broken off with the removal of the steering wheel and pad.
The horn does not work with the steering wheel and pad installed. However if I put a screwdriver behind the copper contact onto and make contact that way, the horn works.
Did I screw in those four long skinny long screws to far? I have attempted to pull the housing out a little more, but same result. Maybe old brown wire is broken somewhere up stream. I checked and it is connected to the back of the steering wheel housing.
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
Any advice would be much appreciated.
More to come regarding lighting, as I ran out of space to add additional photo's.
Thanks again,
Gary
