remove the steering wheel and turn signal and wiper switches, then remove the ignition cylinder clamp via the two slot head screws. you will then see a hole in the side of the steering lock cylinder, push a paper clip or small screwdriver in the hole to release the ignition key switch tension clip and withdraw the key cylinder
QUOTE(northern chris @ Jun 1 2019, 05:21 AM)
I am parting out a 1973 2L that was in an accident 30 yrs ago and I am trying to remove the ignition switch but I have no keys. It there a clean way to remove the steering lock and related switch assembly without having the key?
