QUOTE(dabird @ Jun 2 2019, 08:32 AM)
I have two injectors that leak in the same place after the car has been sitting for the winter. after letting the car run for a bit, shutting off and restarting they don't leak again until the car sits for an another extended period of time. There was a recent thread where another person experienced the same thing. I can only assume there is a seal that shrinks when it dries out and then swells again after some use. I bought replacement injectors but decided not to install them.
Thanks Dabird
The Car has been standing for 2 years, started it once in august last year and for the second time today.
Its leaking a lot of petrol from the injector making me worry about the risk of a fire.
I will let it run ans see if the seals swell. How long did you need to run the car before the injectors stopped leaking?
