The very popular fog light flash module:
The way the car should have been wired. Signal other drivers easily with a flash of your fog lights using the column lever.
As an added bonus, once the kit is installed the fog lights can now be turned on with headlights off (if desired).
The 914 Fog Light Module is easy to install with no wire cutting and no modifications to the original harness.
Operation: When the headlights are off and the column stalk (turn signal lever) is moved toward the driver, the fog lights are turned on as long as the stalk is held. When the stalk is released, the fog lights turn off.
When the headlights are turned on, the stalk toggles the high-beam headlights on and off as usual.
This item works with all years of 914/4 (does not work with original 914/6).
Just PayPal me $10 to cover shipping and its yours.
