QUOTE(Mark Henry @ Jun 5 2019, 04:43 PM)
The full mark should be the same.
Yes it will take more oil and you may have to run it for a minute to fill the oil lines and filter, then check and top up to the full mark.
Filter is about a half quart, if the cooler is in the rear maybe another half quart extra. Run for a 15-30 seconds, let sit a few minutes and check level.
Cooler and lines will fill in seconds, I'd expect to see the idiot light to go out in less than 10 seconds.
Yes, but for cornering on the track, I want to 'overfill' the engine, with the old trick of 4 qts instead of the 3.5 qts that it would take to fill the engine to the dip stick MAX mark.
But I guess in this lies the answer, I could fill it up to MAX and add 0.5 qts....
