QUOTE(porschetub @ Jun 8 2019, 05:29 PM)
As mentioned that a large increase from stock...wow,don't really remember but didn't the T1 kits go from 1.2 to 1.4 to 1 or so,think the drag race guys when to 1.5 or more using roller rockers with offset pivot blocks.
Do you plan to fit offset rocker pivot blocks to restore rocker geometry ?,no expert here just asking.
Mark is "dead on'' with his comments on the heads,the exhaust valve ports are horrible and all restricted by very small exhaust valves,still wonder why VW designed this way ? perhaps that why they went to square port for a short time ,you simply can't port them out enough to really benefit from larger valves...there is a limit with stock casting.
Hope member HAM chimes in here for comments on the stock heads.
Well, since you asked.
The thing about T4 exhaust ports is this: They get a bum rap. Across the board, every T4 head VW produced has a perfect ex/in port flow balance of around 75%. I've flowed them all and they all have this perfect balance in stock form. This is an excellent ratio and represents modern ratios that emerged in the "enlightened" era, when designers realized that 1:1 ratios were not needed (or helpful) in building torque. A way of thought that was firmly set in place by the mid 60's.
When it comes to T4 head modifications to both sides (by that I mean intake ports and exhaust ports) we have no trouble safely modifying the exhaust ports to maintain that target 75% ex/in port flow ratio with a 44mm intake valve.
We have also had plenty of success at exceeding 100hp/liter on high revving 1.8l & 2l 914 race engines with stock sized valves. Both ports need work but are easily up to that challenge. (Remember that the largest displacement factory T4 was 1971ccs, so obviously the designers did just fine with both ports for the intended use.)
In considering at what point the exhaust ports become a hindrance consider the current state of the art of normally aspirated ProStock drag racers who are running ex/in port flow ratios down in the 60% range.
We learned a long time ago that we can go way up on the intake port flow and still produce an exhaust port capable of keeping up over 60% (split duration cams are the norm for these engines), and producing gobs of torque on large displacement engines.
The issue that limits these large displacement engines is the simple fact that we can't fit a suitable size exhaust pipe between the pushrod tubes without pinching the exhaust pipe.
With large displacement engines, the restriction becomes the exhaust system due to the location of the exhaust ports, not the exhaust ports themselves. The facts outlined in the above paragraph are what limits the rev potential of large displacement T4's. We can crutch the decreased ex/in port flow just fine with split duration&lift cams and well designed exhaust systems, but we can't get a big enough pipe bolted to the engine. This is why the T1 port design opens the potential for large displacement T4's. Large displacement T4's are great for gobs of low-end torque, but if you want to rev them hard to make big HP you need to make the switch to aftermarket heads.
I do not remember off the top of my head at what lift point the stock springs go to coil bind, but it's not very high, and at any rate they do not have the pressures to handle aggressive lift rates.
Aggressive lifting will require dual interference springs for the pressure needed as well as to prevent destructive wave action.
I think it's great that the OP is willing to try new things and break parts along the way to greater understanding. I will say that in my professional opinion a 1.7:1 rocker will likely present valve train issues with any cam designed for stock ratios, and at high revs on cams designed for 1.5 ratios.
But, don't let me deter you from finding out on your own, and I will be quite pleased if you prove me wrong. Proof to the contrary is how we learn and make progress.
