carl k
Jun 6 2019, 08:55 PM
SOLD!
Here's a complete set of drilled, studded 5 lug hubs and rotors for a 914. The fronts are the later type with the hub centering ring. Front rotors have screw in studs and are cast with a "411" part number, so perhaps they were OEM. Rear hubs have 65mm long, press in studs with backup TIG welds.
Rotors have little to no wear, are smooth. Fronts measure .428" thick, rears are .369" (both within the tolerances of new rotors). I don't think the car from which these came was really driven after being converted.
SOLD
$450 for everything (no core charge for rear hubs) plus shipping. Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentthanks!
Carl
bdstone914
Jun 7 2019, 07:45 AM
Good deal for the right person.
The buyer should know that the 65mm studs in the rear hubs require 21mm spacers. That partially threaded stud style stud does allow a lug nut to tighten down with out a spacer. Not easily swapped as they are welded in.
Good luck with sale.
Bruce
carl k
Jun 7 2019, 07:52 AM
Bruce-
Yes, these were used with spacers on a flared car. Thanks for pointing that out.
Carl
carl k
Jun 12 2019, 12:35 PM
Bump- possible free delivery to Sacramento/Truckee regions this weekend.
-Carl
carl k
Jul 26 2019, 06:25 PM
can ship in three large Flat Rate boxes anywhere in the continental USA for $65.
-Carl
