brainf18
Jun 8 2019, 04:26 PM
I was looking for a set of 6.5x15 steel wheels for track days. I wanted to run 205/15's all the way around. Wasn't able to find any low cost "off the shelf" solutions for an unmodified 4x130 bold pattern. So I settled on 5.5in wheels and ordered a set from Sierra Madre Classics. ($59 each)
When the wheels arrived, they looks suspiciously larger than 5.5 inchs. So I put a tape measure on them and to my surprise they were just a few mils under 6.5 inches wide. I test mounted this morning and the backspacing and offset were spot on. Problem solved. Though others might like to know...
https://sierramadrecollection.com/Steel-Whe...1-2-p19583.html[/url]
Click to view attachment Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
michael7810
Jun 8 2019, 04:49 PM
I don’t know how to measure wheels but those are 5-1/2 measured on the inside of the bead edge
porschetub
Jun 8 2019, 04:58 PM
its done on the inside where the tyre mounts...wish they made a 6.5'' size they would sell like hot cakes IMO.
mark04usa
Jun 8 2019, 05:35 PM
Sure is a fine looking steely, though. Haven't seen any 6.5" steelies.
brainf18
Jun 8 2019, 05:49 PM
QUOTE(porschetub @ Jun 8 2019, 06:58 PM)
If that's the case then its still a 6 in wheel....Can still run a 205 tire.
DickSteinkamp
Jun 8 2019, 05:52 PM
Wheels are measured inside to inside of the bead. You have 5 1/2" wheels.
Jun 8 2019, 06:01 PM
QUOTE(DickSteinkamp @ Jun 8 2019, 07:52 PM)
Yep.
brainf18
Jun 8 2019, 06:46 PM
Well bummer! thanks for the clarification. If you hear of anyone making 6.5in steel wheels let me know. I guess I'll just run 195's and be happy!
michael7810
Jun 8 2019, 07:08 PM
I run 205s on my 2L Fuchs and they are 5.5s. 30K miles with no problems
porschetub
Jun 8 2019, 07:51 PM
QUOTE(porschetub @ Jun 9 2019, 10:58 AM)
Yep said that
,don't know anyone making a wheel this width ,you will be fine with 205's as so many doing the same,keep the profile correct and that saves a incorrect speedo reading also.
chrisg
Jun 8 2019, 08:01 PM
What do they weigh? I assume all steelies of similar size are in the 18.5 lb. range, but just for curiosity sake, can you let us know?
brainf18
Jun 8 2019, 09:08 PM
QUOTE(chrisg @ Jun 8 2019, 10:01 PM)
Digital scale says 18.1 pounds
80’s old school
Jun 23 2019, 07:19 PM
Have you mounted these up yet? I want to see what these Steelies look like on the car with 195 or 205 tires.
Mark Henry
Jun 23 2019, 08:17 PM
You could make your own in 15x7"
Grind the welds out of a set of old wheels for the centers, buy a set of barrels and weld them in.
A hub and a lathe with a big enough swing would make the lay-up job easy.
I did the 24" front wheels on my tractor with just a straightedge and a caliper and it runs straight, mounting/measuring on a lathe will be very accurate.
When I bought my barrels 15x7" were available.
sixnotfour
Jun 24 2019, 03:28 PM
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62
https://www.summitracing.com/parts/usw-131-5630/overview/
IronHillRestorations
Jun 24 2019, 06:56 PM
QUOTE(sixnotfour @ Jun 24 2019, 01:28 PM)
https://www.summitracing.com/parts/usw-131-5630/overview/I thought 4.75" was the most backspacing you can get on the rear of a 914
Jun 24 2019, 07:08 PM
I was wrong. 7" 911R wheels will go on the back of a 914 and the backspacing for those is 138mm which is 5.43"
80’s old school
Jun 24 2019, 10:10 PM
QUOTE(sixnotfour @ Jun 24 2019, 02:28 PM)
https://www.summitracing.com/parts/usw-131-5630/overview/Cool. If this size is for real. This will be the ticket for me.
Thanks.
I will check into this further. I noticed my local Americas Tire carries this.
