dralf
Jun 9 2019, 02:18 PM
I have spent some time attending to the engine of my 2.0 L 1975 with D Jet. It has on occasion just quit as I was cruising down the highway. Thanks to many tips and suggestions form this board I addressed numerous potential problem area. This included points, coil, wiring and proper grounding. I was all excited to take the car to the local Cars & Coffee but never made it for it was acting up just as before but with a bit more regularity. This time I was not as panicked and noticed that the engine occasionally cut out at 2500 RPM when it was under load such as going up a hill. The engine would eventually restart ( similar to a push start ) as I coasted down the side of the road. I have since checked the MPSs and it rapidly leaks down a vacuum. This is a rebuilt unit form AA . I installed it 10+ years & 3000 + miles ago. I also noticed that my vacuum advance diaphragm on the distributor does not hold a vacuum. My question is: are these two issues possibly the source of my problem? My second question is can I just purchase a new / rebuilt diaphragm unit for my distributor since the unit itself seems OK ?
Bleyseng
Jun 10 2019, 07:19 AM
If the MPS leaks down fast the diaphragm needs replaceing and the unit recalibrated. The vacuum can on the dizzy as far as I know can't be rebuilt so find a good used one. Its not that important and wouldn't be the cause of your issues. A failing MPS is going rich as engine vacuum can't pull the diaphragm to the lean position inside so the AFR is wonky.
GregAmy
Jun 10 2019, 07:22 AM
Send your MPS to Chris at Tangerine and have him rebuild and tune it. It really transformed my street car.
http://www.tangerineracing.com/mpsdiaphragm.htm
