jagalyn
Jun 12 2019, 05:30 AM
I purchased a circuit board and replaced it on my tps for my 73 2.0.
I still have a slight hesitation from light cruise to moderate cruise so I took it over to a local Porsche shop to have it recalibrated and they are telling me the TPS is bad. That the ohms jump around and open and close circuits. I was very careful replacing the board and followed the YouTube video and everything looked great. My car runs fine under acceleration but has a slight hiccup at light cruise to moderate cruise.
Do you have any idea of what my problem might be?
JeffBowlsby
Jun 12 2019, 08:04 AM
HA, that’s funny. A Djet TPS has nothing to do with resistance like a modern TPS does. It’s not a potentiometer. It’s a progressive ladder of circuits that open/close as the throttle opens, to initiate additional fuel pulses while accelerating. Forget resistance. Just test it for alternating continuity. What is it...22 clicks of additional pulses? I forget without looking it up.
On the stumble, have you oiled the dizzy weights lately? 1 drop of 30 wt oil into the hollow center shaft of the dizzy does it per the FWSM.
bdstone914
Jun 12 2019, 09:50 AM
Clueless Porsche dealer. They should not have charged for wrong information. They should have looked at a factory manual for TPS info. I would take a printout of the factory manual to that recognition and service advisor. I can get you that info if needed.
As suggested it may be a distributor issue. I would check the vacuum advance. I have found the sliding plated get gummed up and do not move.
Requires complete disassembly to clean properly. I found that after cleaning a distributor it took half as much vacuum to fully advance the timing.
Bruce
