Tjmrfe
Jun 12 2019, 09:23 AM
Hey Guys, couldn’t take the leaking oil anymore....so, in a bold move, I decided to pull the motor! I’ve got everything sorted, all my ground straps and wiring is off...went down the check list, got my Tangerine plate and my dolly...now all I need is a guide, or two?...I’m more than willing to throw a BBQ together and refreshments I’m thinking the second weekend in July? 13/14....either day works...should not take too long, just four bolts right? Lol...I’m in Cornwall NY near West Point...PM me if you’ve got a free few hours that weekend, this way I can get it out and see how bad the oil leaks are!...
ndfrigi
Jun 12 2019, 09:31 AM
you’re almost there to drop your engine. For sure you can do it by yourself.
Is your current lifter can drop your engine all the way down a furniture dolly and the highest to raise your car (rear valance) can get around 29”? so you can pull the engine. (engine and dolly height is around 28”)
Or use 2 floor jack to raise and lower your rear car during the engine removal.
1. All cables remove like clutch , accelerator, speedo
2. All wirings to top engine (F.I. or carb)
3. Tranny ground strap
4. Remove exhaust (it is fine also not removing it but easier and more space to work underneath)
5. Raise your rear a little bit enough for your to work underneath.
6. Loosen the tranny and engine mount bolts just enough for you to totally remove them later
7. Put your furniture dolly under the rear (vertical way of ur dolly)
8. Drop your rear slowly one side at a time (if using 2 floor jack) until
the engine touches your dolly (engine mount drop to one side of the padding of your dolly and rear end of dolly pad along tranny and you may need a small wood block for dolly to tranny) Note: check also your rotor that may hit the floor
9. Drop rear that engine is totally seated to your dolly. Note again: Check again if rotor is not hitting the floor.
10. Remove engine and tranny bolts.
11. Raise your rear car slowly and always check on top your engine bay to see if clearance are all okay. You may use 2 jack stand just for additional security but don’t forget to lower the floor jack every time you lower your rear until no enough space for the jack stand and you can just put them aside
12. Pull engine out
Tjmrfe
Jun 12 2019, 09:43 AM
QUOTE(ndfrigi @ Jun 12 2019, 07:31 AM)
I took off the rear valance, and was figuring that lowering the car down to the dolly, removing the bolts, and lifting the car away from the motor would be the safest. Thanks for the height info...I’ll have to see how high that lift gets. I’m pretty sure she’s gonna make it...
JOEPROPER
Jun 12 2019, 10:07 AM
I wish I had some time. I could use a drive over Bear Mountain... You're almost there. Take your time and be safe about it.
rhodyguy
Jun 12 2019, 10:34 AM
I use the 2 jack method raising under the control arms (rear tires off of the car). X2 for the dolly. Approx match the angle of the car when almost fully lowered and add some dunnage on the front of the dolly. If you have carbs, remove the carbs from the intakes leaving the linkage intact. This preserves your current adjustment. Just loosen the engine and trans attachment points. It's easier than you might think.
rgolia
Jun 12 2019, 01:23 PM
I think a group of 914 guys are meeting in Chester NY that weekend. I am sure someone can come by and help you out, if you are not comfortable doing it yourself. BTW - What you have left to do is the easy part.
Big Len
Jun 12 2019, 02:54 PM
We'll figure out a way to help you out. PM your phone number to me.
iankarr
Jun 12 2019, 03:03 PM
I’m in northern Westchester and am happy to come by and help. If you haven’t seen it already, my engine drop video is in the list on the link in my sig below...
injunmort
Jun 12 2019, 04:02 PM
i'm free. lets do it before mid july, then you can drive over to tech sesh/bbq. I am 20 minutes away. pm me. if you need tools, jacks/stands/dolly let me know.
rhodyguy
Jun 12 2019, 04:23 PM
Problem solved!!! Great bunch of people.
dabird
Jun 12 2019, 04:34 PM
I grew up in Orange County, NY. This thread is making me homesick
Big Len
Jun 12 2019, 04:58 PM
rgalla9146
Jun 12 2019, 07:57 PM
I saw Ian at Bear Mt. tonight and he mentioned your post.
Can you handle about 10 eager helpers ?
I'm in too.
Rory
PS ..your car looks great.
bigkensteele
Jun 12 2019, 08:31 PM
I do it by myself. I use a jack under the engine bar to replace each outer mount bolt with a long piece of 3/8" threaded rod, two flat washers and 3 nuts (two on top locking each other and one on the bottom. Replace each side and tighten all the way.
Put jack under rear of transmission and slowly lower each side of the engine bar by using a ratchet wrench on the bottom nut of the threaded rod. Lower the rear of the trans as needed.
This method allows very precise control of the drop which is nice if you still have your fuel injection intact since the clearance on the sides is pretty tight.
... Or have a couple of guys over and get to know some fellow 914 enthusiasts!
Tjmrfe
Jun 13 2019, 05:26 AM
Wow, as expected, you guys couldn’t have been more helpful. Looks like I’ll get by with a little help from my friends! Thank you and hopefully my next picture will be back behind the wheel...thanks again...
Terry.
Jun 13 2019, 05:39 AM
Get a Tangerine jack plate and make it an easy, one person effort. Most people only regret not buying one sooner.
http://www.tangerineracing.com/tools.htm
BeatNavy
Jun 13 2019, 05:52 AM
QUOTE(mepstein @ Jun 13 2019, 07:39 AM)
Cornwall is a pretty place. Tackling 9W over Storm King in a teener would be a blast.
Tjmrfe
Jun 13 2019, 05:58 AM
QUOTE(rhodyguy @ Jun 12 2019, 02:23 PM)
The best....
IronHillRestorations
Jun 13 2019, 06:45 AM
+1 on the Tangerine engine plate, but you'd need 3 floor jacks. I'm so spoiled with my 2 post hoist.
bdstone914
Jun 13 2019, 07:00 AM
@Tjmrfe I would be very interested to see if the Quik Jack can lift the car high enough to clear the engine coming out the back.
Removing the filler neck reduces the engine hieght.
It can be done alone but it good to have a helper to watch that it comes out well with nothing catching.
And do you have those rubber blocks for thto give a couples inches more height.
Bruce
iankarr
Jun 13 2019, 07:33 AM
QUOTE(bdstone914 @ Jun 13 2019, 09:00 AM)
Bruce
Hey Bruce...
Yep. I've been doing it with Quick Jack. With the standard blocks you just have to take off the rear valance.
VaccaRabite
Jun 13 2019, 10:30 AM
QUOTE(cuddy_k @ Jun 13 2019, 09:33 AM)
Bruce
Hey Bruce...
I bet if you only put blocks on the rear that would be enough angle to not have to remove the valence.
The Quickjacks that I have used have all been taller then my 3 ton jack.
IIRC you need 19 inches off the floor to get the engine out.
Zach
iankarr
Jun 13 2019, 01:11 PM
Actually...using the tall blocks that come with the QJ allows the engine to clear...but they're a little less stable. I feel more comfortable just removing the valance and going with the short blocks.
Tjmrfe
Jun 13 2019, 02:34 PM
QUOTE(cuddy_k @ Jun 13 2019, 11:11 AM)
I removed valance, wasn’t too bad, and have her up on short blocks...we’ll see...
Tjmrfe
Jul 13 2019, 04:43 PM
QUOTE(bdstone914 @ Jun 13 2019, 05:00 AM)
Bruce
Hi,
Been a bit busy, but yes, the quick jack was perfect, took the rear valance off...and used a Tangerine support plate on my floor jack, the quick jack was a big help, allowing the to raise and lower with the touch of a button....bought it used, and saved 1/2. I highly recommend it.
Tjmrfe
Jul 13 2019, 06:14 PM
QUOTE(mepstein @ Jun 13 2019, 03:39 AM)
http://www.tangerineracing.com/tools.htmI did and I can’t imagine doing it with out it? Wow...motor definitely would have tipped....thanks.
Tjmrfe
Jul 13 2019, 06:17 PM
Bruce
Yup she worked like a dream, that QJ was ideal.
I removed rear valance, and took off entire F.I. Assembly....slid out like butter...
Bleyseng
Jul 14 2019, 11:05 AM
Jul 14 2019, 11:23 AM
Bit late to the party but we do have a nice write-up in the "Technical Articles" section:
http://www.914world.com/specs/tech_engdrop1.php
Tjmrfe
Jul 15 2019, 06:20 AM
QUOTE(SirAndy @ Jul 14 2019, 09:23 AM)
http://www.914world.com/specs/tech_engdrop1.php Thanks!....and yes I ended up using all the resources I could find. Worked out ok. I think the worst was, like FDR said,...the only thing I had to fear was fear itself...now that I’ve done it once, it’ll be a breeze from now on! Thanks for the input.
